Recently, and I mean within the last week, I have run into an issue with LOG4OM2 not downloading confirmations from LOTW. When I start the download process I get a message that it contains 0 QSO's. I am using the lastest version 2.23.0.0. I've updated TQSL and same problem. I've checked my settings under external services, and everything checks out there. Any ideas why it won't download the ADI file from LOTW?
It also appears to be the case for ClubLog and QRZ. No issues with upload though.
I've checked passwords, no issues there.
Thanks,
Mike, KI1U
LOTW not downloading confirmations
Re: LOTW not downloading confirmations
OK, discovered the problem after a little tinkering.
Windows was blocking outbound requests from LOG4OM. Setting up a new rule for outbound requests for LOG4OM did the trick.
