Hi Guys
I'm brand new on the forum and as Log4OM user as well.
I have some awards on V1 that I don't find on V2, as RDA or EURA, for instance.
My question is: is there a way of copying those V1 awards into V2 and all its information?
Thanks for your help
73 de CU3AA, Joao
Awards V1 to V2
Re: Awards V1 to V2
Hi Joao, we're in process of porting awards but we're not simply "copying pasting" them.
we're trying to update their lists, if applicable.
If you can point me to an updated reference list for them i will add in a day.
Obviously you can also create them and export as XML with the right click context menu. I'll be glad to check them and deploy for all users
User manual will help you on that amazing task
Re: Awards V1 to V2
Hi Daniele
Thanks for replying.
I didn't quite understand if all data I have on V1 can be saved and used on V2. For RDA, for instance, I have more then a thousand references worked. Will I have to update V2 manually?
I send you the latest RDA list.
73 de CU3AA, Joao
73 de CU3AA, Joao
rda_eng.txt
- (105.49 KiB) Downloaded 261 times
Re: Awards V1 to V2
Ciao Daniele, complimenti la V2 è stupenda.....anch’io ho lo stesso problema dell’OM portoghese, nei collegamenti con stazioni russe non risulta disponibile in award RES. Il diploma RDA. Anche con le stazioni cinesi non è disponibile quello delle province cinesi. Le referenze di entrambi i diplomi sono presenti nei rispettivi diplomi in award management.
Grazie per l’aiuto. Aldo I2AOX
Re: Awards V1 to V2
Hi all, Departments of France Award : DDFM V2 , I hope there is no errors
Thierry
https://forum.log4om.com/download/file. ... ew&id=2522
Thierry
DDFM.xml
- (32.73 KiB) Downloaded 417 times
Re: Awards V1 to V2
Also did the DDFM and DPF
award_DPF.xml
- (9.03 KiB) Downloaded 254 times
award_DDFM.xml
- (33.3 KiB) Downloaded 265 times
73 de F4BPO Greg
