Adding 3&13cm bands to QO-100 users
4Z1ZV
Post by 4Z1ZV »
If you are using the offset feature, LOG4OM can display and log the real frequency.
However you need to update the band definition to include the subject bands.
Go to: Users/"your user name"/AppData/Roaming/Log4OM2/bandplan
Change the name of file: bandplan_r1.xml, so you have it in case of failure
Copy the attached file bandplan_r1.xml file to this folder
Restart Log4OM2...
bandplan_r1.xml
(10.3 KiB) Downloaded 395 times
4Z1ZV
