This is my first logging program and I am really enjoying it. I do have another question, I looked in the manual on pages 20-23 but do not find if I can move the large cat screen around the screen.
Thanks again for your help.
Large CAT screen
Re: Large CAT screen
Terry that reminds me of something.
When I bring that up it shows me the modes for both Radio 1 and Radio 2
When I change to Radio 2 it shows no mode. Come back to Radio 1 and no modes anymore there either.
Running Omni Rig and Flex 6600 with Rig 1 going to slice A and Rig 2 going to Slice B and both are on different Serial ports.
- 2020-02-03_10-43-37.jpg (50.22 KiB) Viewed 4505 times
Rich,
I tried to reproduce your observation and I'm not able to do so.
I can change between Rig1 and Rig2 and modes do not disappear.
OmniRig and K3 here.
Log4OM2 v 2.3.0.0
Log4OM2 v 2.3.0.0
I can't emulate it either but I don't have flexradios will ask Lele to check
I just upgraded the software and no change.
Here is an example.
I opened the large window, did a video capture, tuned the rig which is slow to respond but no big deal. Changed rigs (slices) and changed back.
Then closed the window and reopened it so you could see it from the start.
https://vimeo.com/389047745
Here is an example.
Ok i have seen the video. Investigating. Probably on VFO change i'm not asking mode again to the rig.
checking, thanks for heads up
It works correctly if you change Rig in Main UI but not in large CAT Control window.
Flex 6600 - Spiderbeam
