Country File Update??
K0XM
Post by K0XM »
When is this scheduled to occur? I am seeing spots for TO4A which is Martinique but the file is not mapped for that call so the country field is blank. Is there a way it can be updated like on my packetcluster, or N1MM does? Which is with a Country file from ADIC at https://www.country-files.com/??
FM spot.JPG (23.18 KiB) Viewed 3017 times
Re: Country File Update??
Depends what schedule you have set in program configuration
K0XM
Post by K0XM »
Thanks Terry, thought I have it daily....will double check. IS the file capable of being modified by hand?
Same for me on TO4A. My country file download is frequent so that might not fix it for you.
