LoTW won't upload after update to 2.7.0.0
g4rwi
Re: LoTW won't upload after update to 2.7.0.0
Post by g4rwi »
I seem to be making some progress. QSO's in LOG4OM that have "LoTw Sent" set to "requested" are now being sent OK (all the appropriate fields in LOG4OM are also set to "requested')
I do however have some QSO's where the "LoTw Sent" is set to "no" - these dont get sent to Lotw, as expected. What I dont understand is why they have been set to "No", as the qso's are on the same day and consecutive with others that are set to "Requested"
Is there a way to select all the QSO's where "LoTw Sent" is set the "No" and change it to "Requested"?
I suspect some are coming from a JT program and others by direct entry.
Have you watched the three YouTube 'Confirmations ' tutorials?
g4rwi
Post by g4rwi »
Hi Terry
Yes I have watched the youtube tutorials (a few times!)
The only JT program I use is WSJTX. As far as I can see there are no options in WsJTX that relate to this?
I think Im getting really close to everything work properly!
Is there a way to edit the "LoTw Sent" field for multiple qso's?
Yes in both QSL manager and QSO manager
g4rwi
Post by g4rwi »
Thanks Terry
In QSO manager, under single field update, the "LoTw Sent" field is not shown in the list of fields you can edit. Have I done something wrong?
nigelspear wrote: 03 Jul 2020, 18:01 The only JT program I use is WSJTX. As far as I can see there are no options in WsJTX that relate to this?
Did you use JTalert with WSJT-X ? Have seen also a problem here with wrong entries in eQSL uploaqd status
and for LotW it was the same. The problem was a wrong setting in JTalert. Checking the 2 boxes will send
"Requested" to Log4OM.
By the way, to change upload status for eQSL, LotW and others use the QSL Manager. Much easier.
nigelspear wrote: 04 Jul 2020, 08:54 Thanks Terry
No you would have to use direct SQL update in the QSO manager!
Probably easier for you to use the QSL manager which does not require a knowledge of SQL queries
g4rwi
Post by g4rwi »
Thanks Terry
I updated now through QSL manager - very simple thanks for the tip
re direct QSL update - I can see me getting into all sorts of trouble doing that :-)
Thanks again for the support and its a great piece of software, well done
