Loss of configuration
Good morning everyone, I was using version 2.12.0 of LOG4OM V2, after installing version 2.13.0, whenever I close the program it loses the user's confusion and the database, returns as if it were the first time I'm entering and I need to configure everything again. Does anyone know how to solve the problem?
Re: Loss of configuration
This has been answered on several threads. Read the link below and then also click on the link that Terry provided with a search of your same question.PP5XA+ wrote: ↑30 Apr 2021, 11:43 Good morning everyone, I was using version 2.12.0 of LOG4OM V2, after installing version 2.13.0, whenever I close the program it loses the user's confusion and the database, returns as if it were the first time I'm entering and I need to configure everything again. Does anyone know how to solve the problem?
https://forum.log4om.com/viewtopic.php?f=33&t=6611
If accurate this may be a different problem.PP5XA+ wrote:whenever I close the program
Bill
W4WWB
W4WWB
Where is Log4OM stored on your PC, provide paths the user files and also your sqlite database pleasePP5XA+ wrote: ↑30 Apr 2021, 11:43 Good morning everyone, I was using version 2.12.0 of LOG4OM V2, after installing version 2.13.0, whenever I close the program it loses the user's confusion and the database, returns as if it were the first time I'm entering and I need to configure everything again. Does anyone know how to solve the problem?
yes, everything is set up correctly, when I close the program and reopen I need to do everything again, it's like setting it up for the first time!
That does not answer my question, please state paths and locations
my config:C:\Users\User\AppData\Roaming\Log4OM2\user
my database: C:\Users\xxavviiierr\Documents
Windows 10?
What other software is running in conjunction with log4om?
Is log4om being run as an administrator?
Windows 10? R: yes
What other software is running in conjunction with log4om? R: JTDX
Is log4om being run as an administrator? Yes!
Very odd
Please send me a support request from the help menu and include your ADIF
Send to g4pop (at) arrl.net
