Send a Spot AFTER logging??
VK2MET
Post by VK2MET »
Is there a way to send spot AFTER I log a QSO? Often I fill in a QSO and forget to click the send spot before I hit enter. The only way is to re-enter the QSO and click the send spot button.
Is there another way to select the last QSO or the previous one and spot it?
Alan
Re: Send a Spot AFTER logging??
If you klick at the Spot QSO button in the main Window beside the callsign field a
popup is opening with the latest logged contacts.
VK2MET
Post by VK2MET »
Goodness yes - thanks - my mistake
Simply an early morning support B4 I was go to the QRL, HI. No problem.
