Sorry just realised that SDC is a SunSDR interface
frequencies of the 2 VFOs
Re: frequencies of the 2 VFOs
Cris, you might consider HamLib.
Not sure if you are running slicemaster for the flex but its a great program. There is a Log4OM readme file in the zip file that shows you how to connect the Flex to Log4OM with HamLib. It will make both VFOs work and Log4OM will log whatever slice is set to TX.
My only complaint is you need to start the programs in order. Flex, SliceMaster and then Log4om.
hi Rich
thanks for your help, I have to understand how HamLib works many thanks 73 Iz2rlo Cris
can you tell me the settings you made in log4om with hamlib
thanks
thanks
Have you downloaded and installed SliceMaster?
In my setup that's a required component. There is a Log4OM file in his installation zip file giving step by step instructions.
hi Rich
yes i have downloaded slice Master now all ok it works THANK YOU for helping me
You are welcome. Hamlib works better than OmniRig in my opinion but as I said needs started up in the proper order to get to work.
I notice that 'slice b' was not change to be B, but was also A
mine works, so not log4om issue check smartcat again
