Hi, i am using verion 2.21.1.0. When i open qsl detail i can not see qsl info.
Can you help me?
missing sql info
Re: missing sql info
Restore your database and config as detailed in the user guide under 'Emergencies'
thank you for your reply.
I noticed that the problem is somewhere different. In the attachment i exported 2 QSOs.
QSO with UA6HGM was logged in by LOG4OM2 and i am able to see all QSO info.
QSO with SP5GSM was logged in by Log4OM and the QSO info are missing.
Thank you.
73 Michal OM6ADK
Thank you.
73 Michal OM6ADK
- log4om.txt
- (5.53 KiB) Downloaded 74 times
73 Michal OM6ADK
In qso manager your using a date range for the search, dont use a date range and search for all that should show all QSO's
I think that is not the problem.
Please see this video https://youtu.be/7NueZeFPLFA
In OSQL manager i can see the QSL info - sent and received status. But in Edit QSO window on the QSL info tab are this info empty.
Here is the same situation in Recent QSO'S grid. https://youtu.be/HBiWK2bg4vI
73 Michal OM6ADK
Please update to Beta 2.22.0.7 here https://www.log4om.com/download/ I just noticed your on a vey old version
