Ok, I admit I'm being a bit lazy with this request... I'm a new satellite user, and the default list does not include most of the currently active satellites. Does anyone have a list they can share?
73 Bill WT0DX
Updated Satellite List
Re: Updated Satellite List
Bill,
Go to: Settings / Resource Editor / 'scroll down for satellites.csv and/or satmodelist.txt'
You can edit this files as you see fit for your needs.
These files (once edited) will have a "_user" filename extension added so that they won't be over-written with new program updates.
Thanks Nolan, I appreciate the info on how to edit lists. I was just hoping that someone might have added all the newer birds already and would share their list. The default list is very out of date...
73 Bill WT0DX
73 Bill WT0DX
Bill,
Sry ... we've not received any updates as of late and also one of the main reason why Lele made that file user-adjustable as each OM can then pick/choose and keep their own list current.
Once an update is available it will be with a periodic update of Log4OM and also will 'not' over-write the user modified file that you have created.
