Info look-up when updating QSO start-time
pe1eec
Post by pe1eec »
Sometimes I forget to lock the start time of a QSO at the start, so I when I finally pressed it, I change the time to the starting time.
However, every change in the time leads to updating the call info, which I would say isn't required any more since it is already there.
It is very annoying as I can't change the time any further since I have to wait for the call info to be updated.
Also it would be great if I could just simply type the time, instead of using the up/down arrows.
Cheers, Martin, PE1EEC
Re: Info look-up when updating QSO start-time
And you dont like the facility to have the start time automatically actioned when the cursor leaves the Call sign field? Why?
pe1eec
Post by pe1eec »
I didn't know this was a separate setting in the configuration. Never mind, I got it enabled now.
Please discard
