So it 'appears' that you cannot not save the same cluster hostname even with different SSIDs or it overwrites the first.
The hostname function seems to be case sensitive so as a work around I did save a VE7CC.NET and a ve7cc.net.
I am doing this because I have a SSID with human spots covering about 15 US states for spotters. Then I have another SSID for just my state with skimmer turned on. This seems to work pretty well and the skimmer spot reliability is better.
Is there something that can be done in Log4OM that will allow you to save multiple host names?
kd0zv
Save Cluster Issue
Save Cluster Issue
