I enter my QSO data manually not using CAT control. If I change band I noticed that the "RX Band" field is not changing accordingly resulting in false "cross band" operations. Used version is 2.4.0.0
Is there any way to always synchronize main (TX) and RX band?
73 Haiko
RX Band field not changing
Re: RX Band field not changing
Hello Haiko,
manual input is manual input. If yop change TX Band you have also change RX band by manual input.
There´s no automatted change planned at the moment.
By the way, that´s not an Error at this time but a feature suggestion. So will move the topic to that
part.
part.
