I am testing V2.7.0.0 under Win10 and discovered the following.
I activated automatic log to eqsl and when I enter a new qso manually the QSL default message (stored in Settings/User Configuration/Confirmation) is perfectly transferred to eqsl.
But when the qso is logged automatically from WSJT-X (which works excellent without JTAlert) the qso is transferred to eqsl without the default message.
Is there a possibility to activate default message also with automatic logs from WSJT-X?
Matthias, DL9BDI
No QSL default msg to eqsl?
Re: No QSL default msg to eqsl?
Hello Matthias,
at the moment Log4OM logs what it receives as ADIF_Message from WSJT-X or others and don´t override
anything. Would be easier if WSJT-X would have an own "QSL Message" field to transfer it to external
logging softwares which do the upload job but it only uses simple standard ADIF fields.
V2 is a "young one" and i think in future releases this can be possible but for now it´s not a real user
support question. It´s more a feature suggestions question. So i move this post to the Feature Suggestions
part of the forum ...
Thanks Jürgen for the quick response.
Now I know that its not a usage error.
So I will wait for future versions
vy 73 de
Matthias
vy 73 de
Matthias
