In Version 1, when you clicked on a contact in the cluster, it filled in the mode as SSB whether it was USB or LSB. Version 2 fills in LSB or USB and I would like to see it do like Version 1 and only show SSB. Now, when I search for SSB contacts, I also have to include LSB and USB.
Thanks,
Ron, KI4TN
SSB Mode From Cluster
Re: SSB Mode From Cluster
Ron,KI4TN wrote: ↑17 Jun 2020, 15:23 In Version 1, when you clicked on a contact in the cluster, it filled in the mode as SSB whether it was USB or LSB. Version 2 fills in LSB or USB and I would like to see it do like Version 1 and only show SSB. Now, when I search for SSB contacts, I also have to include LSB and USB.
Thanks,
Ron, KI4TN
The slight change has to do with adherance to the ADIF v3 standards.
Thanks, Nolan, for your answer. That explains it and it is not a show stopper. In thinking about it, it will be easy to work around. I have the format of several filters saved in a text file. If I want to find all my SSB contacts, I can use my saved format that will have SSB, LSB, and USB in one search string. Doing it that way won't be any more of an issue than searching for SSB by itself.
73 from Ron, KI4TN
73 from Ron, KI4TN
