ADIF Export
F6FLU
Re: ADIF Export
Post by F6FLU »
IW3HMH wrote: 29 Apr 2021, 09:39
I'll check if i can put the same ADIF selection fields in the QSO export phase
Daniele IW3HMH
Thank you Daniele,
I understand better indeed.
I don't want to use these fields as an ADIF Standard field of course, just being able to export these fields during an ADIF export either by not selecting anything in the ADIF export window or having the possibility to select these fields when I select these fields via " export selected fields "
So yes it would be great if you could create these fields
Dan - F6FLU
https://F6FLU.org
