Would be nice to have an option for the internal server that when enabled only allow the server to transmit spots that are filtered.
Example; if you filter the incoming spots such as "Not Worked", Reliability Threshold" etc, those spots (that are currently displayed) are only retransmitted by the internal server.
Internal (spot) Server to use filtered cluster info
73 de N5HC
/Conny
/Conny
