connecting the configured DX cluster is just one click on the main view. But to connect the CAT interface, on the main page there is only a button to open the separate CAT management window, where you can then connect and disconnect the CAT interface of the transceiver.
I really would like to see a single button on the main screen to connect and disconnect the CAT interface, just in the same way as you connect and disconnect the DX clusters. That would help a lot when switching back and forth between SSB and WSJT-X.
Would you consider that change?
Thanks in advance
Christian DB9CR
Suggestions on CAT
Re: Suggestions on CAT
I dont have any need to switch CAT on and off when changing from SSB to WSJT because I have it set up as per our user guide to use Omnirig on both programs.
