ARRL VUCC Award
Posted: 17 Jun 2020, 14:57
by N5FPW
I'm sorry if I missed this but I did not see the ARRL VUCC on the award list. Has anyone configured this award in their logbook that can provide some guidance now that the VHF/UHF e-skip season is open and I would like to track same? Also if there is no VUCC and again I didn't see it can the Log4OM team add it/
Thanks for the time and your help. This program is looking better by the moment as I set it up.
73 de Larry
Larry Van Horn, N5FPW
US Navy (Ret) ATC (AW)
Brasstown NC
Re: ARRL VUCC Award
Posted: 21 Jun 2020, 13:57
by K4QXX
I was looking for this as well. I have been having to export my log into HRD logbook so I can check my grid squares. Would be really nice if Log4OM would add the VUCC award.
Re: ARRL VUCC Award
Posted: 21 Jun 2020, 16:47
K4QXX wrote: ↑21 Jun 2020, 13:57
You can add it yourself and share it with other users if you can obtain a list of the eligible grid locators
Re: ARRL VUCC Award
Posted: 05 Aug 2020, 15:02
by WR0H
I came across this thread while searching for the same information.
VUCC doesn't have "eligible" grids the way DXCC has eligible entities. It's a per-band award based on reaching milestones such as any 100 grids.
https://www.arrl.org/files/file/Awards% ... RULE1a.pdf
I hope I haven't misunderstood the discussion
G4POP wrote: ↑21 Jun 2020, 16:47
Re: ARRL VUCC Award
Posted: 05 Aug 2020, 16:12
WR0H wrote: ↑05 Aug 2020, 15:02
Thought it was the same as fred Fish and the squares had to be in the USA so that makes it even easier for you to make the award if you dont require a grid list.
Re: ARRL VUCC Award
Posted: 05 Aug 2020, 18:57
by WR0H
G4POP wrote: ↑05 Aug 2020, 16:12
I wish I found it easy, but unfortunately that isn't the case at all. I'm really having a problem transferring what I read in the Award Editor section of the manual into what I need. Reference codes and fields really have me against a wall.
Re: ARRL VUCC Award
Posted: 05 Aug 2020, 20:20
Did you download the LATEST user guide which has a special section about awards written by our awards manager Claus?
Re: ARRL VUCC Award
Posted: 05 Aug 2020, 21:38
by WR0H
G4POP wrote: ↑05 Aug 2020, 20:20
I'm using the one dated 2/8/2020, where the Award Editor section begins on page 122. Page 127 is where I start going off the rails.
Re: ARRL VUCC Award
Posted: 05 Aug 2020, 22:44
If you dont have any luck ask Claus if he can assist you.
Re: ARRL VUCC Award
Posted: 27 Dec 2021, 19:59
by sp5qwb
I made a VUCC award definition file. The file is large (~310Mb) and I can't put it here. If anyone is interested, I will post a link to the file. Unfortunately, there is a bug in the application and the grid with the numbers 00, 01, 02, 03 to 09 is not visible and are not credited, which I wrote about in the previous post.
Bart sp5qwb
