I found that as of end of January 2017, the auto upload to LoTW stopped working.
Manual upload works fine, so I assume my definitions are OK.
Auto upload to eQSL works fine.
Auto upload to LoTW stopped
Re: Auto upload to LoTW stopped
We don´t have had an automatted upload to LotW in any of the past versions. Autoupload is possible for eQSL, Clublog, Hamlog, HamQTH and (if you are xml subscriber) with API Key to the qrz.com logbook. For LotW we only have the possibility for a manual upload.
B.t.w. if you open Settings/Options/External Logs you will see that there is no checkbox for "Automatic upload on new QSO" for the LotW. This checkbox you will find only on the settings for all other services.
