Digital FT8 Mode
vk2hv
Digital FT8 Mode
Post by vk2hv »
Cannot log FT8 mode is there a fix ????
Re: Digital FT8 Mode
A bit more info would help?
What software and how have you set it up
vk2hv
Post by vk2hv »
when you log a qso,,in the MODE there is no FT8 there !!!
I am using latest version
Paul
Since latest Version FT8 must be in the Mode dropdown in alphabetical order.
If not you may have a Modelist_user.csv in your config folder which overrides
the Modelist.csv. If you have a Modelist_user.csv delete it to get Modelist.csv
to work (after a restart).
You can open the config folder via the Help menu.
vk2hv
Post by vk2hv »
Thank you
That fixed the problem
Paul
G4YBI
Post by G4YBI »
Hi I also have this problem, I tried going via the con-fig folder but when trying to open the mode-list I get a message saying no info/programme available, is there any other way to add FT8 to the list, it only seams to be this new update, older downloads were all ok, Thank's G4YBI....
You don't need to edit the mode list the latest releases since last August include FT8
Just follow the instructions in the earlier post and delete the user file
G4YBI
Post by G4YBI »
Hi Terry, Sorry didn't realizes all I had to do was delete it, I was trying to open it !!
All done and working fine, Thanks again Paul G4YBI..
