Actually only prefixes allowed in Norway for CEPT-complaint visitors are LA/ or JW/ , see https://eng.nkom.no/leisure/radio-amate ... -to-norway./LH is a recognised prefix and sometimes suffix for Norway, using it for Lighthouse is not internationally recognised.
Suffixes are not regulated internationally to my knowledge, even /P usage and definition differ from country to country.
Maybe he will realise he had used illegal callsign when having number of QSLs rejected and corrects himself? As I said - if we promote bad practices, they became more common...If we dissable /LH the next time someone signs for example F6ABD/LH it would record France as the country and you would not like that either!
Could you please do it for me? And also all the people putting on the cluster with /LH... ThanksAsk the Lighthouse operators to use only country, mobile or portable suffixes and your issue will be resolved
Using /L or /LH suffix is probably legit in many countries (while bizzare). Using /LH while working under CEPT in Norway is just purely illegal.
73!
Wojciech
