2 of us just installed 1.33.00 and Log4OM is not able to find database.
Tried reconnecting in Options -> database and gives "No database found"
Revert back to 1.32.00 all is well
Dave W0DHB
MYSQL databases are not working in 1.33.0
Re: MYSQL databases are not working in 1.33.0
Hi, i have the same problem.
The message in the log is :
ERROR: *** DatabaseManagement: MYSQL Connection invalid ******* [Function: #=qjzy0vC3AzsGnvIlGoJzD1w==] MySql.Data.MySqlClient.MySqlException (0x80004005): The host localhost does not support SSL connections.
Any suggest before to revert back?
Dave IK7HTB
Dave IK7HTB
Hi Dave, hi everybody!
i have found a workaround :
in the user name in Option -> Settings -> Database Tab, in the username field add ";SslMode=none" (without double quote) to your username. Then Check the connection and Swith to MySQL.
For me works like a charm!
Dave IK7HTB
Dave IK7HTB
Thanks Dave-- I never would have guessed that in a million years.
Works fine now.
I'd add one step.. after you click on the switch to MySQL, click on the save Icon
Good find 1
Works fine now.
Good find 1
Hi Dave,
I had the same problem, thanks for the solution.
Jo DJ4JZ
Jo DJ4JZ
73 de DJ4JZ
Hi Dave
I had the same problem with MariaDB
Thanks for the solution
Philippe on4gpn
Philippe on4gpn
Right. Good Catch
I have just received a log and concluded with the same result.
It seems updated MySQL drivers requires a SSL connection "by default".
I'm preparing a patched version with SSL = NO (by default, for now) and an updated version to avoid tampering connection strings
