HI,
Is it possible to delete more than one entry, as I have 50 entry's I would like to delete all in one go ???
DELETING MORE THAN ONE ENTRY
Re: DELETING MORE THAN ONE ENTRY
QSO Archive manager
Check the box 'Enable delete'
Select (Highlight) the QSO's to be deleted using the normal windows method of Shift/Click and/or Ctrl/Click
Press the 'Del' (Delete) button on your keyboard
I have gone into Archive but cannot see (Check the box 'Enable delete') I can see the Enable updates/Enable removal but can't see the 'Enable delete'.
Terry G0VWP
Terry G0VWP
Removal and Delete mean pretty much the same thing. Did you select that option? I'm sure it will work for you.
Nolan,
Thank you for your help all now removed logbook all up to date.
Terry G0VWP 73
Terry G0VWP 73
I did try growing up once, but it was no fun at all.
Whoops!
This option works well. Go to the QSL Manager. At the bottom right hand corner there will be a Lock icon in Yellow. Clicking on that will change it to Red. Select records to be deleted. For multiple records use Control key. Then from Key board click DEL. This will delete the selected records.. VU2GRM
Thread is nearly 2 years old and also in the version 1 forum which is on maintenance onlyvu2grm wrote: ↑26 Jul 2021, 07:23 This option works well. Go to the QSL Manager. At the bottom right hand corner there will be a Lock icon in Yellow. Clicking on that will change it to Red. Select records to be deleted. For multiple records use Control key. Then from Key board click DEL. This will delete the selected records.. VU2GRM
