Icom 756 ProIII interface
Posted: 19 Oct 2019, 23:08
I am having a little problem with the Beta release of the Icom IC-756 ProIII interface. The problems I noticed are...
1. When I click on a cluster spot the frequency is changing but the Mode is remaining the same as it was. So if I am on 20M SSB and click on a spot that is 20M CW the rig will change frequency but stays in SSB instead of changing to CW.
2. When I click on a spot that has a QSX frequency it is not putting the 756 ProIII into split and setting the 2nd VHF Freq.
3. When I work a station Split it is not logging my transmit frequency from the second VFO but does log the Receive frequency as the "Transmit Freq".
Since DX4Win was working perfectly my guess is that there is something wrong with the command line or more likely I am doing something wrong
Thanks Guys!
Rory, K5CKS
Thanks Guys!
Rory, K5CKS
