UDP problem?
G8GNI
Re: UDP problem?
Post by G8GNI »
Thank you. All of those are ok, EXCEPT I forgot to change the location in JTAlert. All now fixed. Thank you so much.
I use LOG4OM on two different stations - HF and VHF - and was hoping that Dropbox might work provided I didn't try to use both logs at the same time. But clearly not.
Thankyou for your time. Much appreciated.
Re: UDP problem?
G8GNI wrote: 15 Jun 2024, 06:59 Thank you. All of those are ok, EXCEPT I forgot to change the location in JTAlert. All now fixed. Thank you so much.
So the time out is OK but you have a Dropbox sharing issue?
I have used Dropbox for years bur recently changed to Google drive because I got a better deal but all worked fine with both.
Contact me by direct email at g4pop (at) arrl.net and I will try to help you
G8GNI
Re: UDP problem?
Post by G8GNI »
As per email advice from terry I have installed Google Drive on both PCs and pointed LOG4OM and JTAlert at the Google Drive log file. Logs are synchronized automatically via the cloud. All working perfectly.
