Hi!
I have an annoying problem with the program: Adif export fails repeatedly at my computer. After opening and starting adif export, the export window freezes/halts until it is killed with x. This results, however, an incomplete adif file - nearly complete exept the mode is missing from all records. Any ideas about the cause or solution of this problem?
de oh8nw/ Pekka
Adif export fails
Re: Adif export fails
I think you have a bad download or install and suggest that you do the followingoh8nw wrote:Hi!
de oh8nw/ Pekka
1. MAKE A BACKUP
2. Uninstall Log4OM
3. Download the latest version again
4. Restart your computer
5. Reinstall Log4OM
Please always provide a full description of your set up when requesting assistance
e.g.
Computer spec, Log4OM version, other software also running at the time, Rig, Interface between radio and computer, Omnirig or Hamlib, Windows version. A step by step description of your actions when doing the export etc
Any information that you can provide helps us help you and avoids dozens of emails, just saying 'It don't work' or 'It crashes' is not a lot of help!
As there has been no response we must assume this issue is closed
