Voice Keyer ?
IK6CRE
Voice Keyer ?
Post by IK6CRE »
When I try to record my CQ in "Audio Config menu" I obtain the error "WaweFileWriter was not disposed in NAudio.Wave.WaveFileWriter.Finalize():
Anyone have this ?
TNX 73
Errore registrazione.PNG (8.83 KiB) Viewed 7878 times
Re: Voice Keyer ?
Can you reproduce the issue and send me steps to repro?
Also you can send me by email a "support request" from HELP menu (only after issue appears) so i can check log?
pse add a reference to this thread in notes
ik3gig
Re: Voice Keyer ?
Post by ik3gig »
Same problem and same errors here
windows 7 64 bit
ik3gig fabio
any solution?
Re: Voice Keyer ?
Not yet, i'm still investigating. I cannot reproduce that issue :(
N5ZY
Re: Voice Keyer ?
Post by N5ZY »
I have the same problem. Windows 10 64-bit..
Can we perhaps record the files and put them somewhere and manually add a path somewhere?
I can easy record audio to wav or mp3 using Audacity.
Re: Voice Keyer ?
Same issue for me. I cannot record OVER previously recorded files either.
50% of the time it crashes Log4OM
Re: Voice Keyer ?
What's your Log4OM version?
Re: Voice Keyer ?
Sorry, did not get back to this. I was running the latest version when I posted a response but in the last week I have upgraded to the one you just released.
I am getting this message. I am just in recording stage. Have not figured out how to connect to radio yet. Using a Flex with DAX.
Is the call recording section just for recording and listening to the Wave files?
Can I get some clarification on the 4 I/Os please?
Re: Voice Keyer ?
kd0zv wrote: 19 Mar 2018, 20:17 Sorry, did not get back to this. I was running the latest version when I posted a response but in the last week I have upgraded to the one you just released.
Appologies for the delay in replying Rich but I needed to do some extensive testing.
I can now confirm that although everything works fine when you first make a recording that when you try to overwrite an existing recording that an error message is received.
Furthermore if you choose to delete the old message it is not deleted
I have asked Lele to look at this issue and will get back to you once it is resolved
W3FA
Re: Voice Keyer ?
Post by W3FA »
Not sure if my question should be here or another thread but it seems related. I am trying to set my voice messages up. I assume that the mic to record the messages is plugged into the computer soundcard?
On that screen there are 2 sections that can be changed to select various inputs and outputs. One I think is a connection to the radio and the other has to do with recording. What should these settings be? Mine is not recording anything.
Jim
Jim/W3FA
