This was to be my first label print from LOG4OM after upgrading to Windows 10 (32bit) and after updating LOG4OM (1.25.0.0). I use continuous 62mm paper roll in my QL-570 with successful results in the past.
The issue now is that everything is being printed extremley small. It is if the fonts are being scaled to an A4 sized label not one that is only 62mm wide. I have updated the printer driver, and also printed off labels using the Brother utility without any problems.The first screen shot is the default setup from label design set for the QL-570, the second is a label preview with the font size set to 50 point.
QL-570 and version 1.25.0.0
- 2016-04-28 (1).png (42.57 KiB) Viewed 3034 times
Re: QL-570 and version 1.25.0.0
Not sure what you are doing wrong or what problem there may be with your set up but I use the QL570 and this is the results I get with Log4OM Version 1.25
Settings as below
Results in the following:
Settings as below
As there have been no further posts on this issue should we assume the issue was a set up error?
Sorry for the delay but I have only just returned to play radio.....
Yes it was a set up error.
I was thinking I had a problem because when setting out the parameters in 'Label Design' the sheet format always shows A4 under the layout diagram.
Many thanks,
Ian
Many thanks,
Ian
