JT6M raport in the log problem
Robert SP8SN
Post by Robert SP8SN »
Hallo. I see some problem in default raport in JT6M mode. There is not available standard MS report, 26 for example. When I log QSO, the report is changed to 00. I can not change it. Always is 00, even if I edit QSO and updated, nothing will change. The log is 00. Everything is ok in JT65 mode. Raports are in dB - OK. Pse some help.
Best 73, Robert
Re: JT6M raport in the log problem
I am able to log a JT65M QSO with -26 and it logs fine, or am I missing something in your forum post
Robert SP8SN
Hallo. Yes I see, but your raport is -26 not 26. That is a difference. A small detail HI :D .
So I will be wrote "-" before raport and everything will we ok.
Thanks for info. Best 73.
PS: However, the problem is not solved
How can I write raport 37,
I write:
and later when I'll update:
Last Edit: Just I added more raports to file /users/me/AppData/Roaming/LogOM/reportlistJT.txt, now -37 is available.
Thaks
We have never ever been requested to add positive DB values for JT65 but I suppose there is always a first time!
You can modify the RST list yourself as shown in our user guide and videos!
Go to the options window Select config tab and check the box marked 'Enable Expert mode'
Then select button 'RST JTxx Mode' as below
Add the required values to the list and in the 'File' drop down menu click 'save'
Click save on the options window and restart Log4OM
Now you have your values in the list as below
Settings 3.jpg (30.66 KiB) Viewed 3279 times
And a recorded QSO will save the values as shown in the final screen shot below
Robert SP8SN
Thank You, all clear !
73 Robert
