Hi Log4OM users.
I run monthly a UHF Contest here in Scandinavia
Using a special logprogram (Tucnak) and there after do an adif export !
After import of this adif with QSO data to Log4OM - including all grid locators, I use the *QSO archive* function and select all the imported QSO's - and run the *update info* function...
This is a very nice feature, except there is no update to distance information.
How do you get the *Distance field*in the log - updated with relevant distance to stations ??
Is this a missing function or do I do something wrong here ?'
Best regards
OZ8PG
Per
Distance field update
Re: Distance field update
Dr OM G4POP.
Many thanks for your help - as usual !
So easy to do, when you know how to do it !!
It worked first time !!
Many 73's
OZ8PG
Per
Many 73's
OZ8PG
Per
