Hi, I am trying L4OM but because of my monitor placement (2nd shelf) I would like to move all windows around so i can position the logging windows t the bottom of my screen.
Is it possible to move the Map to the top and logging windows around? I have found the 'detach' option on some windows but not map or log entry.
The monitor is a 29inch wide format Asus so moving the monitor to the bottom (or 1st) shelf is not an option.
Many thanks
Mike GU4EON
Move or detach any window?
Re: Move or detach any window?
Mike,GU4EON wrote:Hi, I am trying L4OM but because of my monitor placement (2nd shelf) I would like to move all windows around so i can position the logging windows t the bottom of my screen.
Many thanks
Mike GU4EON
No it is not possible to detach the input or map windows as they are part of the main framework.
Version two however will be different and will probably suite your requirements.
Thanks Terry,
That begs the obvious question, when is ver 2 due for release?
Sorry if this has been posted elsewhere.
In the mean time I'll stick with my "floating window" version.
Mike
GU4EON
Mike
GU4EON
