QSL Label Design Default setting Avery 8160
W2MJP
Post by W2MJP »
I accidently hit the A4 button on the bottom of the label design box, Now I don't know the correct margines. IE: Vertical Horizontal in the corrective factor and the printer top margine and so on. Can someone tell me what they are. I'm using AVERY 8160 labels. Thanks.
Mike-W2MJP
W2MJP
Re: QSL Label Design Default setting Avery 8160
Post by W2MJP »
So when I print it seems only the right column is off ( 3rd row). It prints on the break line of the sticker to the left side of it. It is not centered. I spent 3 hours trying to adjust. I tried using the label design but the margine is at 0 already. I also tried making the font smaller but that dont work either. 73.
Mike-W2MJP
Just select the 8160 template again from the drop down list, it won't have been overwritten unless you saved the A4 size to the 8160 template
W2MJP
Post by W2MJP »
I tried that, but I hit save after I thought I may have had the configuration. How can I put it back to default? Or can you screen shot the original 8160 label design box? Thanks.
Mike-W2MJP
Unzip the attached template to your C:\Users\YOUR USER NAME\AppData\Roaming\LogOM\labels folder and let it overwrite the one already there
AVERY 8160.zip
(417 Bytes) Downloaded 300 times
W2MJP
Post by W2MJP »
Ok thanks Terry.
I will try this when I get home from work. 73. Enjoy your sunday.
Mike-W2MJP
It will work I have sent you the original template!
