Please consider the following feature.
An ability to select multiple bands for including spots in the Cluster window. For example, in the early morning before sunrise I want to see spots for 160, 80 and 40 meters but not the rest of the bands. After sunrise I want to see the higher bands but not 160 and 80 meters.
Thanks and 73, Glenn - KD0Q
Multiple Band Selection in Cluster Window
Re: Multiple Band Selection in Cluster Window
You can already do that by sending a band filter to your cluster provider from the cluster command line in Log4OM
See http://wiki.dxcluster.org/index.php/DXS ... ing_Manual
1. In Log4OM go to Utilities/cluster
2. Enter the filter in the 'Send Command' field as shown below
3. Then click on 'Send Command'
If you are connecting to VE7CC Cluster, band mode filter settings are different, explained at http://www.bcdxc.org/ve7cc/ccc/cccdxbm.htm.
In either case, I think filter settings have to be followed with sh/mydx command or something to refresh the Cluster tab.
I was hoping for something more along the lines of replacing the dropdown band list with a set of checkboxes so that the change could be done in place.
73, Glenn KD0Q
73, Glenn KD0Q
