Hi All
I'm using Log4OM 1.28.0.0 on Win7x64 Professional.
I have a Strange problem in Utilities > Statistics & Awards > Gridsquare
I haven't used the Gridsquare section before so I don't know if this is a "new" problem. I have only used Awards, which works fine for WAZ.
My log contains only Phone QSO's. When I open the Gridsquare tab, it shows Mixed: 630 wkd, 448 cfmd / 182 not cfmd. When I then select a different mode (e.g CW) it adds 630 wkd and does the same (adding 630 wkd) every time I change mode, even when I go back to Mixed. The number of cfmd / not cfmd doesn't always change, that seems more random. Closing the statistics & awards window and reopening it gets me back to the starting values mentioned above, but the behaviours is the same and is the same after closing & restarting Log4OM.
Is this a known issue / bug?
Thanks & 73
Tony YO3IPR / G4IPR
Re: Strange problem in Utilities > Statistics & Awards > Gridsquare
It was not a know bug but it is now!
Bug Confirmed
I will ask Lele to check this out.
Bug Confirmed
I'll check.
thanks
thanks
Thanks Terry & Daniele
Fixed in version 1.29.0 released 1 Aug 2017
