Digital mode RST of +00 error when editing
ve3rx
Post by ve3rx »
I just started using Log4OM, and imported a bunch of 6M contacts done in digital mode. It all looks ok except when I double click on a QSO to edit it, any RST of +00 shows up as +30 in the edit field.
The Log4OM list of valid RST goes from -01, 0, +01. Seems there is some bug when trying to read +00 as a RST.
Also, if one enters +00 as a RST, it takes it, but shows +30 once the edit is saved.
Steve
VE3RX
Re: Digital mode RST of +00 error when editing
From log4om settings folder (help menu -> open settings folder) locate file called: reportlistJT.txt
make a copy as: reportlistJT_user.txt
Find row: 00* and rename as +00*
(* must be mantained, it's the default value... if you want you can change it, moving the * value elsewhere)
save the file and restart log4om.
