Wrong QTH of DX-station
4U1ITU is moved to Africa? What is wrong?
- QTH-error.JPG (182.91 KiB) Viewed 7958 times
73 Olaf DK2LO
Re: Wrong QTH of DX-station
Just saw that, same wrong QTH for XZ1Z - what has happened - any idea ??
- XZ1Z.JPG (183.23 KiB) Viewed 7952 times
73 Olaf DK2LO
If you are refering to the map it would seem that you have your station locator inserted in the settings incorrectly?
Locator, and country must be inserted as below using your details
- Capture.JPG (31.61 KiB) Viewed 7946 times
yes the information is ok in the "country and iota" window but not on the world map and on the right side of the main window distance and short/long path is wrong and the locator also looks strange.
My location is ok and the problem does not show up with other DX-calls I tried, e. g. PJ4M Bonaire I just tried.
I assume the wrong locator (its the same in both cases) of the DX-call is set automatically, but I dont know from where.
By the way I take the calls from the F9 Cluster - strange thing? Does it work for you with the DX-calls I have the problems?
73 Olaf DK2LO
Please check the settings menu 'Station details' it is your own locator and country that is set incorrect as shown I'm my last post - See the screenshot
here are my settings. Do you see any errors? I think its ok. My QTH is also shown correctly on the map ...
- dk2lo.JPG (60.18 KiB) Viewed 7938 times
73 Olaf DK2LO
check for new releases says: latest version.
About says 1.15.0.0 - see picture.
- log4om.JPG (70.03 KiB) Viewed 7932 times
73 Olaf DK2LO
I used your settings and all works fine for me, see images
Suggest a bad install
1. Uninstall log4OM
2. Download a fresh download of the latest version and install it
Let me know how you get on please
1. Uninstall log4OM
- Result working fine!
- Capture.JPG (232.04 KiB) Viewed 7932 times
- My Station using your settings
- Synchronicity.jpg (111.04 KiB) Viewed 7932 times
I just found the error. After forcing the update (via settings menue) of the clublog and SCL databases now the DX QTH is ok. One of these has delivered the wrong data. Now everything is fine.
Thank you for the support! A useful experience if this error happens again to other users.
Will stop now for today ...
73 Olaf DK2LO
