Log search/filter
N9BBE
Log search/filter
Post by N9BBE »
I've been using Log4OM for quite some time and can usually get around the program pretty good. This one has me stumped. I want to filter or search for all log records that have something entered in the the 'QSL Via' field under the QSL tab. I use that field to enter QSL managers and routes. I don't see that field in the drop down in the Search Parameters utility. Tried to enter a custom parameter to no avail. Any ideas?? I didn't find anything in Terry's videos or the manual.
Jeff - N9BBE
Re: Log search/filter
It is there!
Select QSL Sent Via and search type != (Not equals) leave the data box empty
So this is like QSL sent via when the field contents are not blank for those that do contain information
or
Select QSL Sent Via and search type= (equals) leave the data box empty
So this is like QSL sent via when the field contents are blank for those that do not contain information
N9BBE
Post by N9BBE »
Hello Terry. OK I understand but that's not what I'm looking for. I want to search on the 'QSL Via' field, not the 'QSL Sent Via' field. I attached a screen shot. The field I want to search on is circled in red.
log4om_ edit_window01.jpg (234.7 KiB) Viewed 2994 times
Jeff,
In my defence it was late at night, sorry for the miss interpretation.
You need to use "QSL Route" this is the ADIF field name we use Via to make it more understandable.
I have checked and QSL Route is in the list and it works fine
N9BBE
Post by N9BBE »
Terry, no problem. I should have posted the screen capture in my first post. You know the saying, A picture is worth a thousand words...
Thanks for the info on the field. That's what I was looking for. Your the best...
Jeff
