This issue with K9FD is caused because it is listed in the Clublog exception file which does not contain a grid reference
Here is one of the Clublog exceptions for this call:
<ExceptionRecord>
<End xsi:nil="true" />
<Start>2010-07-15T01:00:00+01:00</Start>
<Latitude>21.3</Latitude>
<Longitude>-157.9</Longitude>
<Cont>OC</Cont>
<Ituz>0</Ituz>
<Cqz>31</Cqz>
<Adif>110</Adif>
<Entity>HAWAII</Entity>
<Call>K9FD</Call>
So your QRZ lookup which contains the correct Grid reference is being overridden by the Clublog data and because that does not provide the reference Log4OM is using the 'Centre of the world' locator.
Try turning off the Clublog exception check in the Log4OM options/settings 1 tab and then try entering the call again for lookup
- Capture.JPG (30.37 KiB) Viewed 5967 times
- Capture2.JPG (30.39 KiB) Viewed 5967 times
I need to check with Lele to see if we can use the QRZ locator when the call exists in the Clublog exception file or perhaps calculate the locator from the Lat/Lon provided in the Clublog file.
