DX cluster commands
AB7R
DX cluster commands
Post by AB7R »
How can I add a cluster command to the list that is available with the drop down field instead of having to type it in all the time? With the filters set for various spotting sources the command for me to see DX based on those filters is show/mydx.
Tnx
Greg
AB7R
Greg - AB7R
Caldwell, ID
Re: DX cluster commands
Hi Greg,
if you use the HELP button in L4O you can open the configuration folder. There you´ll find a "clustercommands.txt" ..... Maybe that is the thing you are looking for (not really shure) ....
cu ;) ;)
Yes in the first tab of the options window there is a check box which when checked reveals the editable files, one of those is for the cluster commands
Detailed on page 35 of the user guide
AB7R
Post by AB7R »
Thanks! I use this all the time and keep learning :)
Greg
Greg - AB7R
Caldwell, ID
