Happy New Year!
I am having some trouble with the frequency-mode mapping with the DX Cluster on 40m. I would like to modify the band plan to my liking, but I'm not certain of the file. Would I be looking at bandplan_dxcc291.xml in the US?
Also, should I call my modified file bandplan_dxcc291_user.xml?
73!
Band Plan Files
Band Plan Files
-- Dana, KA1WPM
Re: Band Plan Files
After a quick forum search,you may check this out:
viewtopic.php?f=5&t=2739&p=16438&hilit= ... lan#p16438
Re: Band Plan Files
KA1WPM wrote: 19 Jan 2019, 02:45I am having some trouble with the frequency-mode mapping with the DX Cluster on 40m. I would like to modify the band plan to my liking, but I'm not certain of the file.
Yes
No
Save it as bandplan_r2-user.xml then it wont get overwritten when you install new versions of Log4OM
Re: Band Plan Files
Terry, Rolf,
After trying the suggested file names that both you and Rolf gave, the program still loads bandplan_dxcc291.xml only.
So far I have tried bandplan_r2-user.xml, bandplan_r2_user.xml, bandplan_dxcc291_user.xml and bandplan_dxcc-user.xml. Is bandplan_dxcc291.xml taking priority over these other file names?2019-01-20 17:51:39.4035 INFO: FileManagement: BAND PLAN begin load database for region 2 / 291
2019-01-20 17:51:39.4085 INFO: FileManagement: Bandplan loading dxcc file: C:\Users\Dana\AppData\Roaming\LogOM\bandplan_dxcc291.xml
2019-01-20 17:51:39.4235 INFO: FileManagement: BAND PLAN load database completed
-- Dana, KA1WPM
Re: Band Plan Files
beware,"_user" not "-user" -> bandplan_dxcc291_user.xml is the right format
Loading order is:
bandplan_dxcc291_user.xml is searched as first
if not found
bandplan_dxcc291.xml is searched and loaded (if exists, not every country has a specific file)
if not found:
bandplan_r<your region>_user.xml is loaded, if exists
if not found
bandplan_r<your region>.xml is loaded
File loaded is reported in LOG.
If you see a message: Custom Band Plan: Trying to recovery
that means log4om cannot deserialize the XML (malformed) and then loads the standard base region file for your zone.
Loading order is:
- DXCC - USER FILE
- DXCC - Standard file (if exists)
- REGION file - USER FILE
- REGION file - Standard file
if not found
if not found:
if not found
Re: Band Plan Files
Hi Lele,
I just tried again with bandplan_dxcc291_user.xml, but nothing indicates a custom band plan or failure. There is a WCM failure later in the log, but I'm fairly certain it has nothing to do with this.
Ciao,
Dana
Ciao,
Dana
-- Dana, KA1WPM
