Addresses in QSL label queue
W1SFR
Post by W1SFR »
When I queue up QSL's for printing the address shown is never complete or in the right format and I have to go to QRZ, search for the call, copy and then past the correct address into the QSL card template before printing. Is there a fix for that?
Steve
W1SFR
Sudbury, VT
http://www.kx3helper.wordpress.com
Re: Addresses in QSL label queue
W1SFR wrote:When I queue up QSL's for printing the address shown is never complete or in the right format and I have to go to QRZ, search for the call, copy and then past the correct address into the QSL card template before printing. Is there a fix for that?
Steve
W1SFR
Sudbury, VT
All that you need to do is click the green buttons indicated in the screenshot below to update the address of the station or his QSL manager - No need to cut and paste.
See the user guide for full instructions
You do need to either have your options set to QRZ if you are a paid subscriber or to the free HamQTH for this to work
W1SFR
Post by W1SFR »
Yes. Well in my case, when I update I get the name in the proper field, then in the address field I get:
City
State
Country
In that format. No address, No zip code, and as in the example above not in the proper format
Address
City, State, Zip Code
I have checked QRZ as well as HamQTH and both are correct and I'm able to log into each of them, and they are set up properly.
Steve
Steve are you a subscriber to QRZ like do you pay money for the service?
I did not ask, but I assume that you have completed the Settings 1 menu and in particular the area within the red box in the screenshot below?
This is the result that I get with the same call sign
Screenshot 2013-10-30 18.49.59.png (59.15 KiB) Viewed 8596 times
W1SFR
Post by W1SFR »
Yes Terry, they are both filled in.
OK,
Which are you using QRZ or HamQTH?
Which version of Log4OM are you using?
Do you pay for QRZ?
W1SFR
Post by W1SFR »
I've tried both with the same results.
The version is 1.15.00
Steve
Again do you pay for QRZ?
Steve,
Make a backup of you data
Uninstall Log4om
Download a fresh 1.15 Log4om
Install the new download.
The only thing I can think of apart from you having used the wrong user name and/or password for QRZ/HamQTH is that you might possibly have had a bad download or install.
What version of windows are you using?
Let me know how you get on
