CPU usage after starting Log4OM2
sq9jxb
Post by sq9jxb »
CPU usage after running Log4OM ranges from 5 to 21% after moving and then stays at 45-50%, CAT off, I do nothing with the program.
  OK, enough error information for now. :)
Others probably also have mistakes.
Greetings from Poland
SGC PowerClear, EMU0202
73!
Jan SQ9JXB
Re: CPU usage after starting Log4OM2
There are a couple of activities made by Log4OM in the background, without affecting the user interface.
One of them, as example, is calculation of VOACAP data for each 4 digit gridsquare of the world starting from your locator. Those data will be refreshed hourly and are used by cluster screen, heavy in calculations.
There is a screen that shows what is happening in background, in the diagnostic page (the last error is also reported here, if any)
Please note errors are NOT necessarily real errors. They could be raised by a moltitude of situations, even normal. We log everything because can be helpful for further debug in case of issues.
sp3p
Post by sp3p »
Try turn off Cluster Server
Pawel SP3P
Make certain that 'Trace mode' is not turned on in config, should just be 'Info'
EI2GLB
Post by EI2GLB »
When I switch to TX I find that cpu usage for log4om jumps up to over 75% and slowly falls down during the 15 second FT8 tx period,
Seems ok on RX
Trevor
EI2GLB
CPU usage when you switch WSJT in tx?????
SQ5TDZ
Post by SQ5TDZ »
G4POP wrote: 17 Jan 2020, 12:27 Make certain that 'Trace mode' is not turned on in config, should just be 'Info'
where is the option Terry
Andrew.....SQ5TDZ
SQ5TDZ wrote: 18 Jan 2020, 11:44
Settings/Program Configuration/Program settings - 5th item down 'Default log level' should normally be set to 'Info'
SQ5TDZ
Post by SQ5TDZ »
G4POP wrote: 18 Jan 2020, 11:53
OK thanks Terry
Andrew.....SQ5TDZ
SV5FRI
Post by SV5FRI »
Hi OMs,
I have the same problem with my cpu perfomance it is 57% as result to fence problem with FT8 decode (jtdx).
I have check it all the previous posts and all is find also i have disable and voadcap.
My pc is Laptop I7 with 8GB memory
Please for your advice
73 Yiannis, SV5FRI
73 Yiannis, SV5FRI
http://www.sv5fri.eu
