I am using 2 screens with my computer.
i opened the band map window. moved it to the secreen (on the screen that it opened on).
After closing and re running Log4om 2 it opened on the first screen. i.e. not on the screen it was when i closed the program
I hope that can be fixed soon.
Dan
band map on wrong screen
Re: band map on wrong screen
That is something that has been requested, but not implemented yet - remembering last window position of the main UI window.
Doug
W7DRM
Doug
W7DRM
thank you for the answer.
Any idea if this will be implemented any soon?
Dan
Dan
Daniele and the team set no dates - as it is totally volunteer work and its very hard to forecast available time and difficulty of the coding. But its on the improvement list.
Doug
W7DRM
Doug
W7DRM
It's something we already have, but for some odd reasons on some PC's that doesn't work. I'm suspecting something related to monitor order set in desk configuration (monitor relative position as set in windows screen settings) and window location as reported by OS.
Hi and thank you
i have just installed 2.0.1.0 and it is OK BUT:
1. The worked before window do not stay on top
2. The cluster window do not stay on top after closing an rerunning the program. When I open it, i opens in a larger size compare to the size it was before closing the program, i.e.it does not remember its size at the moment of closing the program.
I hope this can be fix soon, I think the software is very nice.
Dan Katzman
4Z5SL
Dan Katzman
4Z5SL
Shavuah tov Dan.
Since v7, windows as been not very good at remembering windows positions. Since that time, I have used a brilliant utility http://www.desksoft.com/WindowManager.htm that helps greatly. It is so good, I have purchased a lifetime licence. Support is excellent too.
B'hatzlacha
73 de Guy G4DWV 4X1LT
B'hatzlacha
Thank you GUY, I will check
73.
Dan
73.
Dan
