IE 11 Warning
K7PT
IE 11 Warning
Post by K7PT »
There is a bug in the IE 11 wininet.dll that keeps FTP transactions from executing properly.
If you do any FTP transactions DO NOT install IE 11 or you'll be sorry. :evil:
If you've already installed IE 11, you can uninstall the Windows update and the FTP function will once again work as it should.
I know this from direct/personal experience and it is noted in the various FTP forums and MS forum.
Chuck-K7PT :roll:
VA3AG
Re: IE 11 Warning
Post by VA3AG »
K7PT wrote:There is a bug in the IE 11 wininet.dll that keeps FTP transactions from executing properly.
Chuck-K7PT :roll:
Thanks for the info Chuck! I wish you had posted this earlier because I was having problems uploading a web site via FTP all Saturday and Sunday. Now I know why.
Thanks again!
Aldo VA3AG
Re: IE 11 Warning
Use FileZilla then you won't care what IE does
K7PT
Re: IE 11 Warning
Post by K7PT »
Stand-a-lone FTP clients will work OK but, when you use programs to author web sites as I do, that's where you will run into problems. The web authoring programs that upload use the wininet to do the upload and it's imbedded in IE.
Aldo,
I put this warning up as soon as I found the issue. Good old MS gets us again.
When they released IE11, they introduced this bug.
Re: IE 11 Warning
I suppose it depends what you are doing but I run three sites and use FileZilla without any problem. Might be different if you are maintaining dot net nuke sites!
K7PT
Re: IE 11 Warning
Post by K7PT »
Yes, FileZilla is a stand-a-lone FTP client and will work OK if your just doing file transfers. Most Web authoring programs do not use an internal FTP client.
VA3AG
Re: IE 11 Warning
Post by VA3AG »
K7PT wrote:Yes, FileZilla is a stand-a-lone FTP client and will work OK if your just doing file transfers. Most Web authoring programs do not use an internal FTP client.
I am using Front page to do the authoring and uploading. I will download filezilla.
Thanks.
Aldo VA3AG
