Is it possible to have the CAT active with both Log4OM and JTDX at the same time?
I tried with with Omnirig, but it did not work, only one at a time works.
Thanks.
Log4OM+JTDX+CAT.
Re: Log4OM+JTDX+CAT.
Connect JTDX to the radio first (It needs to control the frequency for it to work)
Aldo VA3AG
Still won't work when I try to activate CAT in Log4OM with JTDX already running with CAT active.
I always thought that only one application at a time can have CAT control.
Not a problem, JTDX CAT control only is enough.
Normally yes. But CAT control via OmniRig is multithreaded, meaning any program which uses the OmniRig app for CAT can share 2-way CAT control at the same time. I am running Log4OM V2, BandMaster, JTDX and WSJTx all with CAT and working. But all have to be started with Admin privileges.
Doug
W7DRM
Hi Doug,
Still not working. Does it make any difference if OmniRig was already installed prior to Log4OM installation? I see that OmniRig installation is an option when installing Log4OM. I was wondering if there is an association missing, since I did not check that box.
73 de Vince
Sounds like an old version of Omnirig check out the Omnirig site but I think latest is 1.19
