Upload to external services from ADIF monitor stopped working yesterday. QSOs from FLDigi and WSJT-X are coming in and being saved in the L4OM2 DB ok, but won't get uploaded to e.g. QRZ, Clublog etc automatically. Manual upload from the QSL Manager works ok.
QSOs entered directly into L4OM2 are uploaded automatically as normal.
I discovered that the option "Upload QSO to external services" was unchecked. Tried checking it, but once I save & apply, then re-enter the Settings, it's reverted to unchecked.
Tried reverting to my initial config set (cloned straight after install) and reentered the ADIF and external services settings, but the same happens: the Upload QSO won't stay checked.
Please let me know if you need any other info.
Thanks & 73
Tim 4X1ST
Stopped uploading from ADIF monitor
Re: Stopped uploading from ADIF monitor
Check this post I had same problem.
viewtopic.php?f=31&t=4520
You have to delete the old one in ADIF Functions then reconfigure make sure both Enable ADIF monitor and Upload QSO to external services are checked.
Thanks for the tip. I believe I did try deleting the entries from ADIF Functions - I'll give it another try. It did work fine until a few days ago
Tim
Tim
I upgraded to the newest version.
Deleted the existing log files in ADIF Functions. Re-entered them, set Enable ADIF Monitor and Upload QSO to External Services. After save & apply, I go back into Settings > ADIF Functions - Upload QSO is no longer set
Yes, but if you look at the command string it says AUTO UPLOAD. I said the same thing hihi.
Tim, you have to obey the correct sequence while configuring it.4X1ST wrote: 26 Jan 2020, 18:10 I upgraded to the newest version.
Deleted the existing log files in ADIF Functions. Re-entered them, set Enable ADIF Monitor and Upload QSO to External Services. After save & apply, I go back into Settings > ADIF Functions - Upload QSO is no longer set![]()
1.) Mark checkbox "Enable ADIF monitor"
2.) Select Adif File
3.) Mark checkbox "Upload QSO to external services"
4.) Click on green cross icon
5.) Make sure selected path and [AUTO UPLOAD] appears in the bottom section "ADIF files"
Hope this helps.
Roland
Flex 6600 - Spiderbeam
Thanks Roland,
I followed the sequence you described, and did save & apply. When I go back into the config, the "Upload QSO to external" is again unchecked, but I do have the [AUTO UPLOAD] against each file. I will be able to check the upload tomorrow.
Tim
Tim
Thanks Tim, just wanna make sure are you running Log4OM V2.2.0.0 ?
The "Auto upload" is actually the setting "Upload QSO to external services". So you are all set.
Roland
Roland
