Hi Terry as requested here the Trace-Log for the Out Of Band error I'm getting on 60m band FT8 on 5.457mhz 900hz on waterfall. I compressed the logfile using WinRAR as it was too large to upload. Many thanks in advance for any help.
Kind regards Roland G0OUC
Out of Band V2
Re: Out of Band V2
Roland,G0OUC wrote: 27 Jan 2020, 13:50 Hi Terry as requested here the Trace-Log for the Out Of Band error I'm getting on 60m band FT8 on 5.457mhz 900hz on waterfall. I compressed the logfile using WinRAR as it was too large to upload. Many thanks in advance for any help.
Thanks for the info, I have removed the file that you posted because it contains your personal information. Best to only email those files direct to me or Lele.
Anyway I found an error in the bandplan_dxcc223.xml bandplan so please download and copy this file to your
C:\Users\YOUR USER NAME\AppData\Roaming\Log4OM2\bandplan folder and let it overwrite the existing file
Please confirm it works OK for you
Re: Out of Band V2
Many thanks for the speedy reply Terry the new file is working fine. 73 Roland
