V2 LoTW QSL upload issue
vk2qv
Post by vk2qv »
Hi
Need some help here.
First time trying to upload to LoTW using QSL Manager. Getting an error saying "Creating folder cannot create........" see attached for full error pls.
73 Ras VK2QV
log40mv2_lotw err.PNG (10.01 KiB) Viewed 4243 times
HB9VQQ
Re: V2 LoTW QSL upload issue
Post by HB9VQQ »
Hi Ras,
do you have a temp. path configured in External Services --> LOTW ? If not do so and try again.
Roland
Flex 6600 - Spiderbeam
NS8K
Post by NS8K »
Roland,
This is interesting. I've not tested without a Temporary path being specified but on page 71 of the User Manual it says a Temporary path MUST be specified. However, in the window where you would define this path it shows as optional (opt). Is this a documentation error or does the window need to be corrected?
73 - Tom NS8K
HB9VQQ
Post by HB9VQQ »
Hi Tom,
yes you are correct, documentation info vs. actual config window are not aligned (yet). It was not working for me without temp path.
Roland
vk2qv
Post by vk2qv »
HB9VQQ wrote: 30 Jan 2020, 13:30 Hi Ras,
Roland
Thank you Roland. Set the temp path. All working fine now. 73 Ras de VK2QV
HB9VQQ
Post by HB9VQQ »
Thanks for the feedback, glad it is working now. Guess documentation needs some updating.
W2MJP
Post by W2MJP »
Can someone tell me where I can find the temp path file?
Mike-W2MJP
W2MJP wrote: 04 Apr 2020, 11:58 Hello
C:\Users\YOUR USER NAME\AppData\Roaming\Log4OM2\temp
W2MJP
Post by W2MJP »
Thank you for the reply Terry, And a BIG Thank you to Doug W7DRM who has been there to answer a few questions for me. V2 is up and running in my shack. A big change from V1 which was also very good. Nice job and congrats to the Log4om team. Keep up the great work. ;)
Mike-W2MJP
